Flexible Components
snellutla
Flexible Components
Is there any way you can make a component flexible and also can impose min and max values for varied dimension.
Sharath
CM10
(To:snellutla)
Realize that flexible psrt will not work correctly in any BOM - you cannot fix index for them.
As far as the other, you should be able to write a relation to give it min and max values.
Flexible components appear correctly in the BOM repeat region with WF4.
CM10
(To:snellutla)
I was told by PTC when I called that you still cannot fix the index. I have yet to verify this as we're on WF3, but if it's true (I hope, but think not), then we'll want to upgrade even sooner.
In Reply to Brent Hartwich:
