Wildfire 4 M092 or M110?
akelly
We're going to be updating tomorrow from WF2 / Pro/Intralink 3.4 to WF4 / Pro/Intralink 9.1. We planned on installing WF4 M092 because:
1) M092 fixes a premature exit problem with Pro/Intralink 9.1
2) There has been a lot of complaining on the Exploder about problems w/ M100
M110 is the current build.
Should we install M110 for "go live", or should we stick with M092?
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
When in doubt, upgrade. In almost every case the newer release is the better
one.
On Tue, Oct 13, 2009 at 7:12 AM, Kelly, Andrew C <
> M100
> Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics |+1 440 326 5555
> | F: +1 440 284 1090
STEVEG
(To:akelly)
I fully disagree. They probably tested 9.1 with M092 and are satisfied with that. A newer build can introduce other issues. So use M092 for the upgrade and test M100 later. And if you look at past emails on the board you will see there is a measure delay with large assemblies that appeared in M100 per Walter Weiss. There may be other issues too.
Steve G
M110 appears to have fixed the measurement delay, and is working out ok
for me so far, but I do not have Intralink or Windchill.
Walt Weiss
jer3d1
(To:akelly)
We have been on WF4 M092 for about two months. No show stoppers here.
WF4 M092 w/Windchill 8 M050
All the best,
Jered
