I'm using Creo 3.0.
How do I edit a flexible assembly component? Seems like a dumb question.
WayneF
simply edit definition of assembling of flexible component. You will see tab containing "flexibility definition".
Hey Martin,
Where is this tab?
By the way - this is for flexible assemble components. I think my description is misleading.
By the way...I still need to get back to the "relation" post i did a bit ago that you were helping with. I've been in "get it done mode",
Wayne
Crap..got it. I have to edit component to dig down into varied items. That just did not seem like the obvious thing to do. I figured it should be in the rmb make flexible area. Thanks!
