Flip projected dwg view 180deg about y axis using weblink or jlink?
RandyJones
20-Turquoise
I have a case where I have preexisting 3rd angle projected drawing views that need to be 1st angle
projection. I want to correct them using weblink or jlink. For example given the following weblink
code snippet (mostly snarfed from pfcDrawingExamples.js):
var session = pfcGetProESession();
var drawing = session.CurrentModel;
if (drawing.Type != pfcCreate ("pfcModelType").MDL_DRAWING)
   throw new Error (0, "Current model is not a drawing");
var views = drawing.List2DViews();
for(i=0; i<views.count; i++)<br="/>{
   var view = views.Item(i);
   if (view.Name == "right_1")
     //some magic webLink or jlink function to reorient 180 deg about the y axis
     view.flip180AboutYAxis();
How would I do this "flip180AboutYAxis()" in weblink or jlink?
1 REPLY 1
Randy,
In Pro/TOOKIT, I would use a transform. I presume you can do the same.
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
