Hi Jeff,
I also recently noticed a similar problem in SolidWorks when creating a helical sweep cut in a cylindrical part. I needed to cut some flats along the top & bottom of a cylinder where the spiral cut represented the screw threads, and the flat removes the threads in that area. The spiral cut was failing when it intersected the cut-out for the flats. Reordering the features allowed the helical sweep cut to work, but the cut-out for the flat itself failed after the features were re-ordered.
So from reading your message, I suspect this problem is common along multiple CAD platforms (at least for Pro-E & SW), and is not limited to Pro-E. If I can find a method to solve this problem with the part model in SW, I would think a similar technique should also work in Pro-E as well.
Chris Thompson
www.appianwaytech.com
In Reply to Jeff Schnellinger:
Group,
Thanks for the many helpful replies. I got many suggestions to re-order
the holes, but unfortunately, this does not change the issue.
Here are some more observations:
As long as the spiral is fully inside the part and not intersecting a
hole, it works fine. However, adding a cut to remove excess material
always fails.
As long as a hole is smaller than three individual 'spirals', it passes
through the holes just fine.
So it seems as the spiral has difficulty when encountering many
intersections.
I also dialed accuracy to the minimum I could ( 0.00001) and it made no
difference
I also got many replies to make a surface and then solidify to make the
cut. I have not tried that, but will give it a go.
Thanks for all the speedy help.
Jeff
Jeff Schnellinger
Senior Mechanical Engineer
jeff.schnellinger@kistler.com
Using Gerry's advice, I believe I found a solution and the solution is similar for both Pro-E & SolidWorks when creating a spiral / helical cut. From the attached JPEG files, I created an external sketch (before the spiral cut) of the excess material to be cut-away, and then created an extruded surface after the spiral / helical cut. To cut-away the excess material, select the cutting surface and "Solidify" (Edit --> Solidify). Be sure to select the remove material option and direction in the solidify feature.
In SolidWorks, it is basically the same produce except that you use "Cut with Surface" in-place of "Solidify" (Pro-E). Also, when working with surfaces, let the surface extend beyond the edge of the solid part in-order to successfully cut-away the excess material. The attached images should be sufficient to guide you through the process.
Chris Thompson
In Reply to Gerry Champoux:
Create the spiral as a surface/quilt. Then solidify the quilt as a cut.
