GD&T dual dimensioning
NSS
Hi all,
Is there possibility to turn off dual dimension for GD&T....
I need it only for dimensions .
TomD.inPDX
(To:NSS)
Welcome to the forum, senthil.
You probably cannot do this with any default settings. All dimensions are treated equally.
However, if you don't need to create the GD&T blocks within the model as GTOLs, you can always create them manually with a note. There are only a few options that are more challenging than most.
I am curious to understand why you wouldn't want the tolerance value to be dual dimensioned?
2 REPLIES 2
TomD.inPDX
(To:NSS)
NSS
(To:TomD.inPDX)
Thanks for your quick reply. I exactly did as what you told.
Machine operators confuse with the primary units(they are familiar with secondary units), thought to introduce secondary units.
For GD&T, I thought it won't be confuse as such and like to turn off dual dimension. That's the reason
