GPU Driver crash
fricchieri
GPU Driver crash
I'm a formula SAE team member, and i have just installed PTC Creo 3.0.
My PC has:
CPU:      i7 4970k
MB:       Asus maximus VII Hero
GPU:     Shappire ATI HD 4890
RAM:     Gskil 8gb 2400mhz
HD:        SSD Samsung 850 pro
The problem is that when i'm opening last year car assembly, or a part. A few seonds later, Creo freeze, black screen and than "Display driver AMD has stopped responding and has recovered".
Obviosly i checked for update but nothing found.
Thank you,
Francesco Ricchieri
3 REPLIES 3
Francesco,
Try turning off some of the newer OpenGL features, and see if that helps.  In your config.pro file, set the following:
enable_opengl_fbo no
enable_opengl_vbo no
enable_opengl_shader no
Dan N.
config.pro in wich folder?
Anyway do you suggest to change graphic card? It's obsolete?
Thank you
mganzer
(To:fricchieri)
<LOAD POINT>\Creo3.0\MXXX\CommonFiles\text\config.pro. Add the options using a text editor, one per line as shown by Dan.
