GTol are erasing off
hmr
Hello guys,
This is one more irritating problem i.e the drawing is having GTols attached to the extension line of the dimension, When I create a PDF from it they will not be available in PDF & then if I regenerate the drawing they will go off from the drawing but they will still be there in Model tree. When I think they are not there & try to create a new Gtol they will appear back, please help me sorting this issue.
Thanks in advance,
Hari
TomD.inPDX
(To:hmr)
Hari, please submit the files to customer service through a case. PTC needs to see this type of behavior.
What version are you using?
