Generative Design
Marcusanthony
Generative Design
Is it possible to use Creo Generative Extension for purpose of generating multiple design variants of same parametric model with dimension variations?
4 REPLIES 4
tbraxton
(To:Marcusanthony)
Yes, but in order to automate this process you would need a license for the Behavioral Modeling extension (BMX) as well as for generative design.
Involute Development, LLC
Consulting Engineers
Hi @Marcusanthony
I might have missed something, or your request is unclear. If the dimensions change, it is no longer the same model.
Could you give an example of your need?
tbraxton
(To:ProFeature)
This is why BMX is required to vary the parametric model dimensionally and then resubmit to the generative design process. It is only semi-automated with OOTB functionality. BMX and GDX will need to be managed manually.
olivierlp
Community Manager
(To:Marcusanthony)
Hi @Marcusanthony ,
Is your question answered? If so, please mark the appropriate reply as the Accepted Solution. It may help many other users!
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Thanks in advance!
Olivier
