Generative design fails to reconstruct shapes in Creo 8.0.0
VD_6920028
2-Explorer
Hello all,
I have used generative design in order to make lighter my design. But when I generated results, the reconstructed shapes had an issue, the Align command for two different curves was not created. I have tried to create manually alignment, but it is not accept it.
Thanks in advance for your help!
Best regards,
Vlas
1 REPLY 1
HI @VD_6920028
Have you tried increasing the part accuracy?
