GetMassProperty of a solid (VB API)
Chris3
I am attempting to write some VBA in Excel that connects to Pro/e and generates a mass properties report for an assembly and all of the components and sub components in it.
I am attempting to use the pfcSolidExamples.vb as a guide, but it uses CType which VBA doesn't support.
solid = CType(model, IpfcSolid)
If anyone has an idea about how to work around this or another way of doing it all together, I would appreciate it. Currently I generating the report with a combination of Pro/e Macros and a little VBA rather than using the API but that's not very robust as it seems like the macros need to be updated with every new release.
Christopher Rees - Mechanical Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Rd, Danbury, CT 06810 U.S.A.
Tel: +1 203 797 5490 Fax: +1 203 797 6637
christopher.rees@utas.utc.com<">mailto:christopher.rees@utas.utc.com> www.utcaerospacesystems.com
1 REPLY 1
Good morning,
in VB you don't need to use CType(), but you have to declare the correct variable types.
For example:
The method GetParam(sParamName)
So it is better to do it this way:
Dim hCurMdl As IpfcModel
Dim hParameterOwner As IpfcParameterOwnerDim
Dim hParameter As IpfcParameter
Set hCurMdl = hSession.CurrentModel
Set hParameterOwner = hCurMdl ' <<< this is the conversion you need...
Set hParameter = hParameterOwner.GetParam(sParamName)
Hope this helps...
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Am Wartfeld 7
D-61169 Friedberg
phone: +49 151 21259910
