I get this strange graphical error in my appearance manager. Does anybody have any clue?
I've posted about this before but cannot find it.
It's a Win 7 issue. What version and datecode are you using? This doesn't affect performance, it just looks crummy.
Sorry, I couldn't find it either. Anyway tanks for the pointer. To day I am running Creo Elements 5.0 M120 but I am trying out Creo Parametric 2.0 and I get the same crummy error. As you said, It doesn't affect performance, and some times it doesn't appear at all, but when it dose, it looks cheap...
I run Windows 7 Enterprise with SP1
Hi Daniel
Are you using a certified graphic driver?
You can also try to start Creo in different compatibility mode in win 7.
Regards
Johannes
How do you mean by different compability mode in Win 7?
I have used a certified driver, but no difference. It has not always been like this, but I can't really remember when it appeared.
Maybe it has when I updated Creo from M80 to M120 to prepare for the update of Windchill.
http://windows.microsoft.com/en-us/windows-vista/make-older-programs-run-in-this-version-of-windows
Most easy way are to right-click and select properties on Creo start icon
Are you on 64 bit Win 7?
We had this issue with M080. We are now on datecode M130 and no longer have the issue.
Aero or non-Aero seemed to have no effect for us.
Yes, I am runing 64bit Win 7. The funny thing is that sometimes it looks just fine. I will try to run M130
Aha! I had posted it on the proecad exploder list; here's the reply that seemed to work for people.
This issue has always occurred on our 64-bit machines (never on our 32-bit ones).
I put the following into our config.pro:
web_browser_homepage about:blank
and the issue goes away!
We had another problem in which creation of a STEP file of a particular model caused Pro/E to exit but only on 64-bit machines. Amazingly we isolated it to the web browser home just like this problem. If we switched to a text-only homepage the issue was fixed.
Please add this to your config and see if it works for you!
Maybe it helps, if you change the display style to a non-aero style.
