HELP Modelling base with curvature. Extrude to shape?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
- I am wondering if anyone can advise how to create a shape similar to this. It seems to be an extrusion up to another shape but I am not sure how
2. Also I accidently seemed to mess something up in the model tab as I now can not delete them from there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Start with the features around the 3 holes. The surface at the bottom of the \/ doesn't actually continue into the "tubes". But I am willing to bet they are parallel to the /\ opposite that region (where the R11 is).
Have alook at the rib feature for that vertical center wall.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
What version of Creo are you running?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I am using creo 2.0
I am not sure I quite get what you mean. I started off by using a reference as my line of centre for my holes (to simplfy the dimensions) So from that line I created the the basic shape of the top part. One thing I am not sure about is where is the bottom placed? I assumed that the rounds more or less continue the two holes on either end but the meeting point seems to be why my shape is slightly off.
That's brilliant Matt. I envy your speed. Maybe you can help with aformentioned question.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Things got a little off when joining the lower base to the 3-hole feature. Knowing exactly what the numbers applied to was less that intuative. So I began with this:
And the numbers stopped making sense when I got tot the merge... something was off. All too often someone will truncate dimensions and they are not as "neet" as they appear. This is what you might be dealing with. This is how I ended up merging stuff:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
If I understand what you are asking correctly, the bottom center area appears to be "double thick" (5mm). 2.5 from the outside wall and 2.5 from the center hole. Your above picture looks like you modeled it at 2.5, so your shape looks more flat on the bottom.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Aha... yes... the R11, R8 and 38 are the key references to determine the angles.
And the center hole diamter is missing! I don't like missing dimensions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi guys,
So I think Ive fixed up the lower angle joint. Easier when you work with the other side.
However I am still unsure as to what you suggest for the trapezoid figure below this section. I have tried to create a square based prism to the bottom and then extend two shapes to this but it hasnt worked so far.
With this I should be more or less wrapped for this part and hopefully move on.
hahah Matt well I will make sure to post if I have trouble with the next one.
Again thanks for your help guys.
Loic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Can you post some pics of what area you are talking about?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Matt
I am refering to the part above the round part we discussed earlier. I just wanted to clarify what you meant by:
" part above the round shaft? Probably because of the way it is dimensioned, just extrude from center 16 at the bottom and 36 at the top. 22 from center. then turn it and cut away from nothing at the top to the 16 width at the bottom (cut will be 2 triangles, or one triangle and a mirror). I can m"
Cheers,
Loic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I made a simple sketch. Does this help at all?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
The trapezoid can be extruded to the full 27 and then trimmed to the angle with a cut normal to the extrusion.
Several ways to make it. I made it using just the 2.5 wall and added a wall to fill the center.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I'm not 100% happy with the way I modeled it. Not really the best methods used. Couple features in there don't really need.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Matt, you got there pretty much the same way I did. The only difference in interpretation is the upper core removal where I stayed with a 2.5mm wall on the angled face.
Also have a look at extrude 9... I just used the optional second extrude direction to fill the small void in extrude 6.
I also see where you had trouble with the fillets in the bottom core removal where the center rib meets the R11. Since rounds don't like jumping boundaries, I had to extrude it.
Of course, leaving the R11 sharp and radiusing it later would also have solved it. But it is one of those things that can cost you a lot of clicking to find out just what failed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Yeah there were a couple things I missed at first and then didn't try to make the tree nicer after. I started out only planning to model the bottom of the part and then decided, screw it I'll just keep going and see how it looks.
So you're right I could have re-ordered 9, extrude 5 I didn't even need. At first I didn't realize how deep the angle went (cutting into that area).
Are you saying because mine is R11.5 at the bottom? I just carried the wall thickness down to the bottom, I didn't even try it at R11.
Loic, come on, we're tired of this one, next part, next part....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I'm going through yours now. Yep, I am assuming the center major diameter is 22 where you have 23. You didn't run into the round limitation because it didn't try to cross over the tangent seam. Easy to do if you assume a 2.5mm wall with the diameter 18 center OD.
I have uploaded the step of what I came up with...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Actually what I find interesting is that in making the changes, most of the rounds fail... but a simple edit definition fixes them without any real changes. Shouldn't regen fix these on their own?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
HI Guys,
so heres the last pozt to wrap it up
- Clamp feature how to especially
- "x" form
- remove material
- base dimensions
- Is it possible to do a shell with a dual shell? (top 3mm and bottom 5mm)
- For the previous part, remember the trapezoid section above the cylinder and ball. So far i completd the design but it isnt allowing me to shell out this drawing-Maybe some advice?
- Excuse me for dredging up the base again but can anyone explain the barrier type feature? On the top face.
CHeer fellas and see you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
If those are the only numbers you have, a couple ideas are to create this new part in assembly mode with the other part. Or start measuring the other part and writing the numbers down or make yourself a print.
I have to look at the rest in a bit.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
This is what that shape looks like to me from that other part.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- « Previous
- 1
- 2
- Next »
