HELP using pro/mold
al204
HELP using pro/mold
HELP using pro/mold
Hello proe users....
anybody out there using pro/mold to design injection and blow molds??
I need help with this module to create the parting line using the silhouette method.
The part is quite complicated.
regards
AL.
mjenkins
(To:al204)
I don't use pro/mold but you can make a silhouette mold parting line by putting your part in an assembly with your mold part and then using Edit > Component Operations > Cut Out
Pick your mold part as the cut out and the part as the reference and it looks pretty good!
In Reply to Alvaro Barboza:
HELP using pro/mold
regards
AL.
Michael R. Jenkins P.E.
Design Engineer
Direct: 816-801-2332
Fax: 816-891-9432
Commercial Vehicle Systems
Haldex Brake Products Corporation
10930 North Pomona Avenue
Kansas City, MO 64153-1215
ptc-1932745
2-Explorer
(To:al204)
I use the TDO (Tool design option) for forgings / castings and
silhouette curves are a neat feature.
Sometimes Pro may show several edges or loops that are recognized for
the silhouette, especially if the part has no draft in these areas.
Most of the time, you can then select the 'TOP' or the 'Bottom' curves
to use in an area.
Several other things may mess this up:
Use absolute accuracy
For parts / molds approx 12" x 18" x 12", the absolute accuracy should
be .0001"
Avoid geometry checks
Undercuts. Make sure you have draft all over. Use the draft check
measurements.
I hope this helps,
Christopher Gosnell
TRIGON INC.
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
