Hi guys ! Is it possible to set a default hatch color in Creo ? I've tried editing the .xch files with RGB codes, but of no use. Kindly help me out. Thanks in advance.
Hi Prashanth,
See if this thread helps answer your question:
Amit
This is the same customer who has raised the doubt with me. I believe it can't be done. Tried many options for this. Nothing works. Thanks for the response !
