Having a Pin Connection go back to start?
Pieface
I have a gear assembled as a Pin Constraint.  When the gear gets rotated it stops at an arbitrary rotational orientation.  When I assembled it using the Pin Constraint I attempted to Rotate it 90 degrees to align with the receiving hole in the shaft.  I could not get it to rotate.  Can someone tell me how I get it to set back to the original orientation?  If it is rotated the drawing will be wrong (see below).
2 REPLIES 2
Pieface
(To:Pieface)
I think I found the answer under the "Rotation Axis" option.
You probably do not need a pin connection.  You can align the two axes and keep them together.
Pin connections are typically required for hinge type connections where you can have dynamic movement.
Two comments:
  • Use snapshots to keep from loosing your valid constraint set
  • You can apply multiple connections to eliminate further degrees of freedom as long as they don't create a fault.
