Helical Pattern Cut
WalterM
Helical Pattern Cut
Is it possible to easily pattern features on a helical path?
For example to make spherical cuts on a cylinder's inside or outside surface.
See attached sketch.
Hi Walter,
Here is a simple solution for you. This video will be released on learningexhange.ptc.com soon, but I wanted to get you an answer. Let me know if this solves the problem. Video Link : 2273
Message was edited by: Steven D Meyers
Hi Walter,
