Help Please ! Library for Creo.
qdomanh
Hi Everyone,
I am a new user of CREO2 M160. Recently I’m working in aluminium  frame design (a KittingTrolley), I tried finding some mechanical components (aluminium frame, angles Plate, trolley wheel) libraries for Creo. I had installed  MISUMI library, but it didn’t work for Creo 2.  would someone please tell me how can i use MISUMI mechanical components library on CREO2 ?.
Thanks in advance
mbonka
(To:qdomanh)
no one gives you original "live part". Most of component dealers give you STEP or IGES file. Open this file in Creo (with appropriate Creo template ---> all parameters, relations etc are correct for your system ---> keep company standards). Resave most used files in your own library.
In generall people use only 10% - 20% of all components, because eachone is focused on something else. Save only most used parts in your own library.
How to connect MISUMI library directly to Creo 2? Ask your MISUMI dealer ---> we are buying commponents from you so l need your help!!! DON´T BE SHY...
Regards Milan
mbonka
(To:qdomanh)
Regards Milan
qdomanh
(To:mbonka)
@Milan Thanks for your answer, Now i'm using Advanced Framework Extension, It is simple.
If you don't mind, i have another question, Do i  need licenses to add Expert mold extension and Creo Tooling Design Extension ? is it not included in Creo licenses.
