I’m looking for a solution to build a Configurable Product in Creo that includes a mechanism.
Here’s the scenario:
What I’ve tried so far:
Question:
Has anyone successfully built a configurable assembly that includes a mechanism?
Any tips or best practices for combining Configurable Products with Motion Skeletons?
Anyone tried to build similar assembly when the configurable product had some mechanism?
Hi, thank you, multiple_skeletons_allowed was already set to yes.
I solved it by create a new level of assembly on top of the skeleton level and created a module from the new level.
Hi @Laszlo_G
Thank you for your question.
Best regards,
I have no experience with the options modeler and without access to your data set I am guessing with this suggestion. You may have multiple skeletons in this context as a result of building the motion skeleton and referencing it in an assembly. If you have not verified this config option try setting it to yes.
Multiple standard skeletons can be created in an assembly when the multiple_skeletons_allowed configuration option is set to yes.
Motion skeleton models are subassemblies that contain design skeletons (standard skeletons or internal sketches) and body skeletons. You create standard skeletons using curves, surfaces, and datum features.
