How can I get the appropriate size of this section drawing?
áwieder
2-Explorer
As you can see it in the first picture, the A-A section of this view is the same size as the view. But actually it should be "higher" - as you can see it in the second picture - because of the type of the section. How can I make a section like the one in the second picture?
GabrielZaha
(To:áwieder)
You need to change the section type to Full(Unfold) or Full(Aligned)
1 REPLY 1
GabrielZaha
(To:áwieder)
