Hello, everyone!
Does anybody know how can I hide datum planes in an assembly, which I made in parts to define geometric tolerances?
They make an assembly look more complicated and hinder me to estimate parts interaction.
There are different ways of doing it.
You can go to Layers and hide all part Datums,
Create a rule to collect the Datums and then hide etc.
Suggest you have a look at the layer tool.
In case your assembly is very large, you may create Zones to work on (View Manager --> Sections --> zones).
You may also want to look at Top Down Assembly and Large assembly management.
Good morning!
Thank you very much for your answer.
It is very useful.
Best regards, Vladimir.
