How can I show a blend's offset from section dimension in a drawing?
spete
Creo 2.0 m080
I am working with a model that contains a blend.  The sections are offset from previous sections.  When I show the annotations of the feature on the drawing, the offset dimensions don't show.  Has anyone run into this before?  How can I show the dimensions without creating the dimensions in the drawing.
MartinHanak
(To:spete)
I guess that the problem can be cause by section. I suggest you to create simple model+drawing and do a test. In case that you will be able to reproduce the problem, please upload your data using How to attach file when you Reply to a discussion.
I tested blend feature in CR2 M070 and was able to display blend dimensions in drawing view.
MH
Martin Hanák
MartinHanak
(To:spete)
MH
Martin Hanák
