I have three flat model of the sheetmetal that needs to output the Bom that can seen largest Length x width x high,beacuse the factory needs to cut them from their size in the Bom.
Their largest Length x width x high of the parameter be change with the models in the Bom.
How could I set their parametric of the largest Length x width x high to the Bom ?
Do you have similar the LISP that I can be revise? ?
Thanks for your help, you do gave me a big favor
你可以借助EMX/PDX 或者使用creo的測量從而得到你想要的最大尺寸![]()
謝謝。若物體是曲面的東西,就無法用測量來量測
不過,我想要的是在elements direct modeling裡做Bom表,裡面可以置入鈑材的最大的範圍,而這個數據會隨著Model改變而一起變動,您這個材料清單是在??
我這個是creo parametric ,當然只要零件的任何變化(只要關係到外形的)最大尺寸是隨著變化而變化,要不怎麽叫參數化呢?使用EMX就可以了
