How do I eliminate a threaded hole in a step file part?
ccruz
This is giving me a hard time. I tried to modify an assembly part that was send in .stp, but when I tried to cut it, the hole remained (see picture attached) and when I tried to eliminate it directly, it erased the part. The threaded hole interacts with the rest of the part as a whole package.
Please give me a hand.
Regards
JLG
(To:ccruz)
You can delete extraneous imported surfaces using the Import Data Doctor.  Edit Definition of the import feature, select the IDD icon:
Then you can select and delete individual surfaces from the tree:
2 REPLIES 2
JLG
(To:ccruz)
ccruz
(To:JLG)
Thanks JLG! It Worked.
Regards!
