How do I force a dimension type in sketcher? Creo 2.0.
rbast
I have a slot that is .6° off the bottom of the part.  I have created a construction line between the ceter points of the two arcs.  When I try to dimension an specific angle it will only pick the end points of the line.  In Catia (my main program) I can choose a dimension type like angle before making the dimension and the program creates an angle dimension.  I can't seem to get creo to behave the way I would like it to.  That is forcing the dimension creator to limit it'self to an angle dimension.  How do I accomplish this task?
I am converting parts from Catia into Creo and need to match the dimensioning scheme.  So an angle dimensoin is required.
Chris3
(To:rbast)
By default minimum_angle_dimension is set to 1. Try adding this to your config.pro:
minimum_angle_dimension .1
Alternatively if you don't know what a config.pro is, go to file -> options -> configuration editor -> add
4 REPLIES 4
Chris3
(To:rbast)
rbast
(To:Chris3)
That is seeming to do the trick.  When I entered it it was set at 1.0.  Changing it to 0.1 is allowing the angle dimension to work.  Thanks.
Tmetcalf
Emeritus
(To:rbast)
Good day Richard,
Glad you were able to get back on track.  If Richard's solution fixed your issue, would you please mark it as a "Correct Answer?"  This helps all following the discussion know the solution.
Best,
Toby
Another trick to work around this is to exaggerate your sketches - so even though the final angle is 0.6°, draw it (by eye) at more like 30°, create the dimension and then change the value.
When creating features around an angled plane as a centreline, I often create it at a relatively large angle (usually 23°, for no particular reason) to the default plane, just so that it's completely clear in the sketch which plane I'm selecting as a reference, and I don't select a default plane by accident.  Then when I'm done, I change the angle of the plane to its 'correct' value, such as 5°.
