I have a slot that is .6° off the bottom of the part. I have created a construction line between the ceter points of the two arcs. When I try to dimension an specific angle it will only pick the end points of the line. In Catia (my main program) I can choose a dimension type like angle before making the dimension and the program creates an angle dimension. I can't seem to get creo to behave the way I would like it to. That is forcing the dimension creator to limit it'self to an angle dimension. How do I accomplish this task?
I am converting parts from Catia into Creo and need to match the dimensioning scheme. So an angle dimensoin is required.
By default minimum_angle_dimension is set to 1. Try adding this to your config.pro:
minimum_angle_dimension .1
Alternatively if you don't know what a config.pro is, go to file -> options -> configuration editor -> add
That is seeming to do the trick. When I entered it it was set at 1.0. Changing it to 0.1 is allowing the angle dimension to work. Thanks.
Good day Richard,
Glad you were able to get back on track. If Richard's solution fixed your issue, would you please mark it as a "Correct Answer?" This helps all following the discussion know the solution.
Best,
Toby
Another trick to work around this is to exaggerate your sketches - so even though the final angle is 0.6°, draw it (by eye) at more like 30°, create the dimension and then change the value.
When creating features around an angled plane as a centreline, I often create it at a relatively large angle (usually 23°, for no particular reason) to the default plane, just so that it's completely clear in the sketch which plane I'm selecting as a reference, and I don't select a default plane by accident. Then when I'm done, I change the angle of the plane to its 'correct' value, such as 5°.
