I am attempting to create a linkage system in Creo. I can parameterize everything so that the linkage system can move and change position, but I am not sure how to track these positions.
Ideally, I would add a few points in, then record their positions for various movement sweeps. I could then export the data to excel and plot the path they took.
I could feasibly do this manually, but I know SolidWorks has an add-in for this and I'm sure there must be some PTC equivalent.
Thanks for any input,
Matt
Do you have the mechanism design module? If so, refer to this thread: Wankel engine port area
