How do I reset a driving dimension to default dimension
pbang
2-Explorer
In a 3D model, the dimension may be changed to a driving dimension by the right button.
May the driving dimension be changed back to a default dimension.
POBang
MartinHanak
(To:pbang)
Per Olav,
when you modify model by mistake, you can try Undo command (CTRL+Z). Also you can erase current model from session and retrieve its previously saved version.
Martin Hanak
Martin Hanák
pbang
2-Explorer
(To:MartinHanak)
Thanks.
I know about when in memory. The problem is on checked in models. You may not want the dimension like driving anymore.
POBang
