How do I retrieve an "AS STORED" revision iteration from Intralink history files
ccooper-szymcza
I need to go back in time..... on a drawing and model within Intralink to
re-create a pdf file of an older revision for historical purposes. Every
time I check out the revision iteration I want, all the parts inside the
assembly are current, not AS STORED for that iteration. What I want is
everything as it was (AS STORED) for that older revision. I haven't done
this in ages but the last time I did there was an option to retrieve an AS
STORED version. How do you do that on Intralink 9.1?
Does any one know how to do this in Creo Parametric 2.0, date code: M010
with Intralink 9.1 date code: m070
Any help is much appreciated,
Reichert Technologies
Connie Cooper-Szymczak
Design Drafter II - Document Control
TEL: 716-686-4576 | FAX: 716-686-3150 | connie.cooper@ametek.com
AMETEK
ULTRA PRECISION TECHNOLOGIES
3362 Walden Avenue | Depew NY 14043 USA | www.reichert.com
0 REPLIES 0
