I have a 8 cond groupshape whos cores/conductors goes from 8 seperate instances of the the same blockshape and terminate in freespace.
It works fine going from connector to connector. By that I mean if I route each end to the first port on a 8pos connector the other seven populate automatically. But how do I route each conductor indivdually like here.
Here is the message i get after placing the first conductor:
try to start routing from the other end of your connector. if you started to rout from port 1, try to start from port 8.
Other option : you can always route standalone fibers, select the fibers and click on Create Cable (diagramming tab->cable group).
