How do I stop it from creating this plate when starting a new part?
PS_10865332
2-Explorer
Thank you!
If that feature is in every new part, it is in your start part.  You need to remove it from the start part.
Hidetaka
(To:PS_10865332)
It is very likely a feature in your start part.
In case you don't know where your start part is located, check the following config option:
template_solidpart
If the new part is sheetmetal:
template_sheetmetalpart
Check this link for more details:
Configuration Options for Object Templates (ptc.com)
