How do you copy an annotation feature from one combined state item to another?
wblanchard
2-Explorer
I have been tasked with creating a new start_part in CREO4 to take advantage of the Annotate/Combined State Items.  I have created a copyright text note on the MBD1_Site_Map item that I want to show up in the same place on all of the Combined State Item Tabs that will be created.  I have pulled CAD examples from the web where this has been done but I can't figure out how they did it. Does anyone have any suggestions?
Wayne,
Try using "Add to state", activate combined state from annotation needs to be copied, select required annotation > Annotate tab > Add to State > Select next state where annotation need to be added.
5 REPLIES 5
Create the annotation in your model, see the model tree and then show in each combined view.
Wayne,
Mahesh
You and Roy seem to be on the same path.  I had gone to this site: Creo Parametric Help Center to get my answer and yours follows their comments.  However, I can not find the "Add to state"  I only find "Remove from state".
OK a little more work on my part and I found the Icon.  Now it works as I had hoped.  Thanks for the prod.
Wayne,
"Add to state" is under Annotate tab, Manage annotations group, is it inactive or not available?
doneill
(To:wblanchard)
Thanks for investigating this!  I added "Add to State" to the right-click menu using "customize"...
