How do you find the Build Date/Code in CREO2
rleseberg
I am going to log a case with PTC support, regarding rounding in family table, and I want to give them the build code that we are currently using.
Can someone point me to the way to find out?
5 REPLIES 5
StephenW
(To:rleseberg)
File - help - about.
I knew it was simple.
Help used to be in the "?" in the upper right corner of programs, but no longer.
Thanks Stephen
BTW, we are using CREO 2 - Build M090, which seems like a low number and probably rather old.
What are they up to with version 2?
We will more than likely go to Creo 4 in another year, but meanwhile, I would like to get onto the most stable build.
Any suggestions on a later stable build?
StephenW
(To:rleseberg)
Stability is in the eye of the beholder. I'm always reluctant to upgrade unless we are having specific problems that the upgrade is supposed to fix...they always seem to come at the cost of something else not working right.
I found the chart at  https://support.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm
Inoram
(To:rleseberg)
For CREO2 M240 has been the most stable for me.
