How do you handle Backshell Ports on Connectors in Creo Schematics?
aoler
I am attempting to build up a new Connector Shape in Creo Schematics that will support adding Backshell Ports to the Connector when needed. I am also attempting to use the Pin Parameter functionality to populate my Connector Contacts with contact specific information.
I am interested if anybody is doing this, I have hit a few bumps along the way, stuck on one now, so I thought I would reach out to see how everybody else is handling this?
2 REPLIES 2
kel
2-Explorer
2-Explorer
(To:aoler)
Aoler,
A couple of years down the track, did you end up fixing your issue? I'm running into similar problems.
aoler
(To:kel)
My variable connector has 2 ports. My backshell ports have a logical name that begin with [1,1]. My contact ports have a logical name that begin with [2,1].
When my connector comes in using BID-WID the contact ports populate based on num_of_pins. I then re-order the connector to manually add the backshell ports where needed.
This works very well as my pin parameter file is based on logical name, the backshell ports are ignored.
