I'm working on a beautiful model, but its beholders are distracted by ugly curves from sweep and style features! How do I go on to hide them?
put the style feature on a layer and hide the layer.
//Tobias
Thank you for your reply!
I want to keep the surfaces from the style feature, but not the curve. I tried thickening the style feature, but then I couldn't mirror it.
Is there a way to find specifically the curves of the style feature when creating the layer? I haven't worked much with layers.
I mirrored the style feature and I was silly enough to try and thicken the mirror feature, rather than thickening the style feature within the mirror.
On the first attempt after lunch I successfully thickened the style feature, and the mirrored version of it.
Also consider the fact that there is a difference in mirroring the "feature" and mirroring the "geometry". (...and mirroring "the part") It all depends on what you are trying to achieve.
//Tobias
if the curves bother you when you are in shaded mode, you can always change your config setting to not show them... (file - option - modeldisplay . (then under "shaded model setting", just uncheck "show datum curve features") )
//Tobias
