How to Save added Columns in Representation Editor Menue for Creo 8 Parametrics
Pius
Hi
I'm creating simplyfied Representations for large Assemblies using Creo 8.0.4.0 Parametrics.
In the Representation Editor menu exists the option to add columns.
But if I add a column and then restart the PC, the added column is disappeared again.
How can I save the added column so that the column always remains?
Thank you in advance.
Pius
Creo Parametrics 8.0 User since 2023
more than 20 years with other CAD tools
Catalina
Moderator
(To:Pius)
Hi @Pius
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
I think changes like that should get saved to the UI file: https://www.ptc.com/en/support/article/CS288341?source=search
Do other menu changes get saved, or is it just changes to this menu? If no changes are getting saved at all, I would check to make sure the UI file is getting saved correctly. Per the article above, the default behavior would be to save the UI file here: %AppData%\PTC\ProENGINEER\Wildfire\.wf\.Settings\creo_parametric_customization.ui
Check to see if that exists. If maybe some system setting is preventing Creo from writing there, I would try setting the config below:
load_ui_customization_run_dir yes
Pius
(To:joe_morton)
Hi Joe
Currently I transmitted your proposal for the saving of the ui file to my cad admin department.
They are now checking whether this is a option for all users. If so, they will implement this change to the creo_parametric_admin_customization.ui which in our environment seems to be the source for the user creo_parametric_customization.ui and the config.pro file.
All my attempts I made to test this locally, where cleared out again at the next cad start-up.
As soon as the modification has been installed by the cad admin, I will accept your proposal as the accepted solution.
Thank you so far, I hope it takes no time ....
Pius
