how to add and show windchill custom attribute into creo->tool-> parameter.
We've done this by adding the attribute in our Creo template, with the parameter name equal to the internal name of the attribute in Windchill. Add the parameter in Windchill to the CAD Document type.
Lastly, be sure to set the parameter in Creo to "Designated"
Hopefully that points you in the right direction!
