One of the customers that I work with utilizes CREO direct and saves their parts in .pkg format. When they send these parts to me I find it cumbersome to open the .pkg file and re-save it as a STEP file for processing later. Is there any way I could automate that small process?
Ideally there is a way to interface with CREO through command line and run a save operation against a part file.
If you have any insight at all it would be appreciated.
Best,
Ethan
Ethan,
Which software are you retrieving the PKG file?
Amit
