hello
I am using a motion skeleton to create a symetric movement for a rail
see attached images.
like this, moving one part move also the other one.
but I can 't find the way to "block"or control the amplitude, to have some limits mini, maxi.
I want to be sure to not have my parts touching.
please help,
I have a couple ideas you could try.
1) Sketch Relation Method
Try using the BOUND() function in a relation to control the min and max values for a dimension.
In my screen shot (snap82.png) I created a dimension between the two legs (sd9). Then I created the relation sd9=BOUND(sd9, 20, 200) where 20 in the min distance and 200 is an arbitrarily large max distance. I can still drag the legs, but they stop at the min specified seperation (20 in my example).
2) Mechanism Constraint Method
If you built your model with mechanism constraints you could accomplish the same thing by specifying a min and max value in a mechanism connection. For example, the cylinder connection allows you to specify a range the assembled part can slide along the translation axis (snap84.png). Same functionality with the Slider connection.
hello
the relations in the sketch didn't worked, but the solution was in de Mechanism Constraint Method
I found thanks to you where to set this dimention in my motion skeleton
thanks
Veronique
