How to change display default part model color as per WF5 in creo 2
dg-2
7-Bedrock
I want to change default model color as per WF5 in creo 2 in all working new part.
5 REPLIES 5
MartinHanak
(To:dg-2)
I think you open template models and can set color in them.
MH
Martin Hanák
Hi Deepak,
You can find some additional information here:
CS22866 - How to set Pre Wildfire 5.0 appearance and color schemes in Creo Elements/Pro 5.0 or Creo Parametric
If you don't have a username and password to access the document, you can create one here.
Amit
your link shows webpage not found or some errors page cant be load
MartinHanak
(To:dg-2)
dg-2
7-Bedrock
(To:dg-2)
i found the answer in simple way my Pro WF5 config.pro i loaded in Creo 2.0. Basic things Background Color changed
