How to change the circular line and arc resolution in creo parametric 3.0
jzamora
It is faceted badly. Is it due to metric format?
2 REPLIES 2
try following config.pro Settings:
edge_display_quality very_high
shade_quality 15
enable_fsaa 16
but be carefull... file size will increase. maybe you have to play with the values to find out the right settings for you.
Seems to be working great, Thanks!
