How to change the type of a point
yguo
As the title, I want to change the type of point, maybe from current "X" to a smaller circle. Is there an option in Creo?
Also, I tried to select this point but I could not, it does not show in the "select list" neither
Thanks.
StephenW
(To:yguo)
There is a config.pro option:
datum_point_symbol
your options are cross, dot, circle, triangle, square
StephenW
(To:yguo)
datum_point_symbol
yguo
(To:yguo)
Thank you. datum_point_shape
