How to convert imported iges(surface) file to solid part?
anatarajan
I have a problem, I imported a iges model file, now it is in surface, how to convert surface model into solid model in Creo 3.0?
Inoram
(To:anatarajan)
If it is not automatically solid then it probably has gaps or missing surfaces. You have to use either IDD or possibly adding surfaces to make it solid (plus possibly a combination of changing accuracy and other tricks). This can range from a few seconds to a few hours depending on how bad the import looks.
The very first hing you can try is select it and hit Solidify and see if that does it.
I think you may posted your question to the wrong Community.   This is the Mathcad Community not the Creo one.
Stuart
Inoram
(To:anatarajan)
Aravind,
Did the information Matt help to solidify the imported data?
You may refer PDF and Sample file in earlier post for information about IDD  Re: Import Data Doctor
