hello,
i need to create a point automaticly whitch is done with the MASS Propriety , this point should be parametric and follow the change of the assembly.
thanks for your help.
SC
I made this Vid on WF2 some years ago for my users, although it's in German I think it might help. Video Link : 7890
thank you but the options aren't awailable , see the picture.
Stephane,
You can use Mass Properties > Feature type > Preview > Feature tab > Check Point at COG
You have to hit the glasses icon and then switch to Feature in the drop down menu, only then the elements on the tab will come to life.
sorry bad picture 😉 this is good! the options aren't awailable
I'm sorry, you are right. This function seems to need some advanced options. With our basic Creo lic this won't work either, only with the Flex3D/CreoEng. III.
I guess you need at least an AAX package.
Behavioral Modeling Extension license is required for the same.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS73023
