How to customize display order of parameters in parameter window?
pcnelson
When creating a new part I would like to set the order of the parameters shown to show the most commonly modified ones first. I have heard of a "rp_config.xml" file that may do this, but I can't find it on my machine. If it is the correct file, where is it? How would I push this out to all users? We are on Creo Elements/Pro 5.0 M130. Thanks!
1 REPLY 1
davehaigh
(To:pcnelson)
Put something like this in your config.pro
parameter_dialog_setup_file P:\Creo 2.0\standard_configs\rp_config.xml
A sample xml is attached. You can export the xml from the parameter dialog if you like.
David Haigh
