How to extrude a sketch which is projected on to a surface
naveenkumar6
7-Bedrock
Hi all,
Is there a way to extrude a sketch as a surface which is projected onto a curved surface.
Thank You
7 REPLIES 7
If the curve is not in a plane then it cannot be projected to create a surface.
However, you can create a surface using the curve as a trajectory, setting the orientation direction, and using a sketched line to represent the projection.
(edit to clarify surface creation.)
Hi, dschenken,
The curve is on a plane and it is projected onto a curved surface, now I want to extrude that projected curve.
pausob
(To:naveenkumar6)
Please provide an illustration of what you are trying to accomplish.  It is very likely that there is a way to do it.
Creo Parametric can only extrude planar curves that are sketch features directly. It uses the sketched curve for the extruded geometry and the plane it's sketched on for direction.
If you've made a sketch, projected it onto a curved surface, that new shape can be extruded but you'll need to create a new sketch from those curves on a plane that represents the new extrude direction. So, create a new sketch on a plane representing the direction you want to extrude and use the "project" tool in sketcher to convert those 3D curve entities to 2D projections on the new plane.  This sketch can then be extruded.
Essentially, you need to project what you projected onto a new plane in order to extrude it.
LinkedIn
dgschaefer
(To:dnordin)
@dnordin wrote:
Check out https://community.ptc.com/t5/Part-Modeling/Extrude-a-3D-curve-or-a-surface-edge-with-Creo-Parametric/m-p/440451 for a video on how to extrude a 3D curve.
Dan N.
Dan,
While technically not an extrusion (though at zero degrees of draft, it's functionally equivalent), that's a very cool technique I wasn't previously familiar with.  Thanks!
LinkedIn
