How to get a preview of Creo Parametric files
tqamar
Hi! I just download a mini project that has been made on using Creo Parametric 1.0 but I have the version Creo Elements/Pro 5.0 installed on my laptop. Whenever I try to open any file of the project then there's no preview available and there is just a blank sheet of Creo in front of me. I've checked each and every file but same problem.
I can see the preview of the part when I change the size of the icon in my window but can't see the part in Creo elements/Pro 5.0 window. Please help me out.
Touseef
3 REPLIES 3
Mahesh_Sharma
22-Sapphire I
(To:tqamar)
Touseef,
Creo data is not downward compatible. Data created in lower version can open in higher versions however not possible from higher to lower version.
Chris3
(To:tqamar)
If you only want to view it and don't care about modifying, it you can use Creo View to open and view it.
Mahesh_Sharma
22-Sapphire I
(To:tqamar)
Touseef,
Did you get a chance to work suggestion from Chris in last reply?
