Hey guys!
Now I'm trying to get dimensions from a part.
What I did:
pfcModelItems_ptr items = solid->ListItems(pfcITEM_DIMENSION);
for (xint dimesionId = 0; dimesionId < items->getarraysize(); dimesionId++)
const pfcDimension_ptr dimension = pfcDimension::cast(items->get(dimesionId));
From the dimension I can get type(linear\angular\diameter etc.), value, additional symbols\text etc. etc.
That's fine. But what about relationship between this dimension(type+text\value) and an actual part\surface\edge\curve.
On the other hand, it would be great to have coordinates for these additional lines\arrows(that build a dimension) + position of the text\value of particular dimension.
Unfortunately I couldn't find corresponding example or some sort of a description in the User Guide. I looked at "22. Dimensions and Parameters->Dimension Objects", p.329
I ran out of ideas ![]()
I would appreciate it if you could give me some advice.
Hi all,
Artem,
Dimensions & Parameters chapter is for driving dimensions - model shape manipulation via dimensions... The functionality to deal with part/assembly dimension semantics ( or cosmetics) is not in OTK as of Creo 3.0 level. You'll need to use Pro/Toolkit and would need a license for 'TOOLKIT for 3D drawing' to access annotation elements in 3D models.
Without that extra license you would get a limited access to dimension properties but in any case you'll get more functionality comparing to OTK...
HIH.
Feliks.
Hi all,
Artem,
HIH.
Feliks.
Hey Feliks,
Thank you for the answer, it really helps.
I found prootolkit User Guide and necessary information in "Dimension Location", p. 577
Now I need only to merge C functions into my code (Standard C++).
Artem
