Hello everybody,
i'm a begginer in the use of CREO, so i would be grateful if you could help me step by step. I have a 3D model with a cavity; this cavity has a curved base surface very variable. In the cavity there are also some internal features at different heights. I have to get the negative of this cavity in order to calculate the volume.
Hi Alberto...
I was able to generate the cavity using a couple of different techniques. Neither is really easy to communicate in this format. One method is better if you intend to keep this "core" and update it as your cavity updates. Another is better just for a quick measurement after which you'd discard it.
Sample model used for this procedure (cavity model). The procedure is shown in WF5 but is adaptable to Creo, too:
I'll try to describe the process and let you ask questions rather than try to document the steps here. Starting with your original model (I'll call it the "cavity" model):
Next, I selected the surface on the other end... and the merged surface from the previous step...
Finally, I merged in the last surface (the complex bottom piece).
I hope that gives you enough to get you headed in the right direction. There are other ways to do this (assembly cutout) but I like this way better. I'm sure someone else might come up with an alternative but this is how I would approach the problem.
Thanks!
-Brian
Hi Alberto...
Are you saying you need the negative of the cavity or of the part. The technique required depends upon your answer.
But if you're just looking for the negative volume of the cavity, there are a few ways to go. You could do a cut out feature in assembly mode. You'd assemble your part with the cavity and then another part with just a solid block of material. The solid block would sit directly on your cavity and ideally "fill it" with a generous overlap into the surrounding material. Then you can use the assembly "cut out" feature to remove material from the solid block leaving only the shape of the cavity.
Another way would be to copy the surfaces of the cavity (using a copy geometry feature perhaps), and then "closing" the volume and solidifying it. You could then take a measurement of the resulting volume.
Do you have a part we can work with or a screen shot? This might be easier to explain with an example or a picture.
Thanks!
-Brian
Hi Brian,
thanks for the answer. I need the negative of the cavity. Unfortunately the part is confidential so i can't post any pics. I found on the internet something similar.I have to get the negative of a cavity like this one.
The part is imported from a PARASOLID file. It's recognised as a unique piece so i can't use the 2nd method. Regarding the 1st method you proposed, could you be just a bit more detailed on the various functions to use?
thank you very much!
Hi Alberto...
Thanks!
-Brian
So much for "not documenting the steps", eh?
Hi Brian,
thanks, you are really kind. The "cavity" model is a unique piece so i'm not able to select only the cavity surface. Furthermore if i try to copy the geometry i can't select any surface of the "cavity" model when i have to "define publish geometri feature". I hope to be clear.
Thanks very much,
Alberto
Hmmm, the negative of a cavity.........a filling?
I guess it is kinda!
Yes it's a filling.
