How to hide Annotations....
ptc-4621603
hi,
in WF4 we had a provision of hiding annotations using layers (when we needed specific annotations to be desplayed, others could have be added on to a new layer and the layer could have been hidden).Now in creo when i try to do the same i'm unable to hide annotation in layers.
Is there any way to do the same in creo.....
4 REPLIES 4
WOW, no answer to this question and it's now 2018!  Running into the same issue in CREO-3.
StephenW
(To:jwindcoach)
What annotations exactly are you trying to hide?
You can turn annotation display on/off with the toggle in the view tab, show, the icon that has a little yellow sticky with an arrow leader attached.
wrsamuels
(To:jwindcoach)
In the annotations tab, select all items in the annotations tree, RMB and remove from state.
I'm using CP4 M040, but should be true across the board.
This is the answer!
